power windows doesent work
Old Apr 7, 2019 | 02:22 PM
Fernando Rebollo's Avatar
Fernando Rebollo
Default power windows doesent work
Hello everyone, I have problems in the windows of my Dodge Ram 1500 1995. I touched both controls of the windows of the driver and the passenger at the same time and now they stopped working.
Check the fuses and wiring, even with a voltmeter and good voltage to the motors. Can someone give me an idea that I can check more?
Old Apr 7, 2019 | 02:47 PM
The motors have built in circuit breakers. Turn the ignition off, wait ten minutes, start the truck back up, and see if they wanna work. If you are getting power/ground to the motors, motor is bad.
Old Apr 7, 2019 | 02:53 PM
Fernando Rebollo
I plugged in the battery for a while, then operated the passenger window only for a single try. then it still does not work Do you think it's the motor?
Old Apr 7, 2019 | 02:55 PM
It's pretty rare for two motors to fail at the same time...... I would more suspect that they are getting stiff/weak, and the current draw trying to move two windows at once, popped the main breaker in the fuse box. (which should automatically reset......)
