HEATER CORE?
Old Dec 12, 2005 | 07:23 PM
White Ghost's Avatar
White Ghost
Default HEATER CORE?
99 DODGE 1500 WHEN I START MY TRUCK I CAN HEAR THE HEATER CORE FILL WITH ANTIFREEZE. CHECKED OVER FLOW AND RADIATOR TO MAKE SURE THEY ARE FULL.
WHAT DO YOU THINK?
THANKS WHITE GHOST
Old Dec 13, 2005 | 02:09 PM
steve05ram360's Avatar
steve05ram360
Default RE: HEATER CORE?
you have air in your system. from cold, remove the cap and turn the heater to full hot then run it until the t-stat opens. make sure you top off the radiator as needed. also it helps to have the front end a little higher when doing this to allow the air to escape.
also i'd suggest making sure you use distilled water and not tap.
Old Dec 13, 2005 | 07:59 PM
Signal 70's Avatar
Signal 70
i'll pass that on to him.....thanks
Old Dec 13, 2005 | 09:25 PM
1996ramkid's Avatar
1996ramkid
whats the diffrence in the water? should why should it need distiled because i seem to have this problem but it's only once in a while?
