Slightly damaged pinion
Old Apr 26, 2019 | 07:55 PM
Jmikk's Avatar
Jmikk
Default Slightly damaged pinion
Hey all, with the Cummins build under way I’m tight on funds to fix my daily driver. The rear axle blew up, broke a spider gear, dropped another one whole and shatter the retainer and cracked the main pin in half. Spectacular explosion and noise, damn near pooped myself lmao. Anyways I have one small small piece of pinion gear tooth broken off just at the tip. Can I order spider gears and the main pin and run it for a while till I can get a new axle? I know it’s not smart but I just don’t have the 300-500 bucks right now.
Old Apr 26, 2019 | 08:17 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Im running around (have been for a year) with 4 missing ring gear teeth and a scarred case
Old Apr 27, 2019 | 10:43 AM
Moparite's Avatar
Moparite
At the tip you should be fine, If the tooth was missing in the middle where the gears mesh that could be a problem.
Old Apr 27, 2019 | 11:34 AM
Jmikk's Avatar
Jmikk
thats what I figured, when the pin cracked and slid back it bit one tooth.
