Bad Socket or wiring? I had a 2010 RAM that was only two years old and had to have the passenger side light socket and wiring replaced. It went bad without any reason.
I wired in a new socket and it did the same thing. I am starting to wonder if it's the on off switch? I'm also considering just running the lights through a relay to a toggle switch.
Black wire is ground, and it's a common ground for both headlamps. Ground G100, but, I can't find where that is. Verify continuity to ground on that wire. See what ya get.
Ok I'll check it out after work. I know the violet and white wire is supposed to be for the low beams but since I dont have any power to that wire on either side that it could be the ground somehow?
You don't have power at that wire? That is certainly a problem.... (also, if the high beams work on both sides, that implies the ground is actually good.) Might want to start with the headlight switch, and multi-function switch.
When I check for continuity do I need to unhook the battery. And yes even on the passenger side where everything works there is no power at any time on the violet wire
I took the truck to the shop today to get tires. I'll check out the switch tomorrow when I get it back. I
took some voltage reading. Not sure if it means anything but the results are in the picture.
