Helpp!!! Coolant leak.
Old May 11, 2019 | 01:45 AM
Isaiah.'s Avatar
Isaiah.
Default Helpp!!! Coolant leak.
I have a 2001 1500 and when i get done driving the truck starts hissing and smoking and i can kinda see a leak in the middle of the engine just above the pulleys smells like coolant and also when i drive my “check gauges” light goes crazy and temp gauge bounces from over heating to normal
Old May 11, 2019 | 07:00 AM
You have a coolant leak. Gotta find out where it’s coming from. The gauge is bouncing due to air in the system from being low on coolant.
Old May 11, 2019 | 07:09 AM
Probably the water pump.
Old May 11, 2019 | 12:15 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
That's my first choice too.
https://www.flowkoolerwaterpumps.com...low-water-pump
These are nice pumps for better than stock replacement. I had one on the Jeep and Corvette. 110 out in the desert, AC on, and wheeling in sand or on the road, stayed at 190 all day. The Corvette 185.
Old May 12, 2019 | 01:40 AM
Isaiah.'s Avatar
Isaiah.
Awesome thank you
Old May 12, 2019 | 08:02 AM
Moparite's Avatar
Moparite
LIMITED WARRANTY AND RETURN POLICY (Effective August 1, 2010) FlowKooler guarantees that its products are free from defects in faulty workmanship and defective materials for a period of two years from the purchase date.
Only a two year warranty. I got tired of replacing water pumps so got a new Bosch pump and a lifetime warranty from where i got it. First one lasted 5 years almost to the day. I'm on the second one witch i think lasted longer than the first. Lost track of when i did it but so far no issues. The one that failed did not leak even when the bearings where bad.
Old May 12, 2019 | 10:27 AM
ol' grouch's Avatar
ol' grouch
Check your thermostat housing to make sure it isn't leaking. If there's no leak there, you can try to wiggle the water pump side to side. If it moves, the bearings are shot and you need a new water pump. If it doesn't move, get in there with a light and look at the weep hole on the bottom of the pump and see if there's a stain from the coolant that has leaked. If you replace the water pump, now would be a good time to replace the thermostat with a new 195 degree one as well as fresh coolant in the engine. The antifreeze protion never goes away but the anticorrosion in your coolant does fade after about 5 years.
