01 pkup 3.9 starts shift in gear then dies
Old May 11, 2019 | 02:13 PM
David Simon's Avatar
David Simon
Default 01 pkup 3.9 starts shift in gear then dies
This might give away: jacked up rear end, put in gear and runs fine. Wheels spinning everything but as soon as you put weight on vehicle and let it down and tires are on ground, put in gear it dies. Am I not getting enough compression to move vehicle or I don’t know, baffled. Engine seems to run fine until your in gear and obviously on the ground lol.
Old May 11, 2019 | 02:44 PM
Have you check compression? May not be a bad place to start, followed by fuel pressure...... Sometimes, a bad crank sensor will do that for ya as well... but, they ain't cheap, and the aftermarket fellers just don't work very well. Gotta be genuine mopar sensor.
Old May 11, 2019 | 03:18 PM
David Simon
Thx I will check that out. Thx for ur time.
