Steering problem
Old May 16, 2019 | 09:06 AM
Ram727's Avatar
Ram727
Default Steering problem
So this started about a month ago after I took off my front wheels to paint them. When I put them back on and went to drive it the next day that is when I noticed that when I turn my steering wheel seemed little harder to turn but the steering wheel liked moved back and forth like it wanted to go straight instead of a smooth rotation when turning. So I re-balanced the front wheels and the problem went away till yesterday it came back. I've checked the power steering fluid, it could use a change down the road but it wasn't low either. Any Ideas?
Old May 16, 2019 | 09:24 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Sounds like something might be binding. I would take a look at the steering column and box.
Old May 16, 2019 | 10:07 AM
lmbarrels's Avatar
lmbarrels
Default no turning at low speed
When turning into a parking lot or parking space, I have no turning unless I rev it up. When backing my trailer it seems to lug. I am also having an issue with front u joint, it fell out while driving down the road and bought a new one put it in and it falls out, are there flanged u joints for my 1997 dodge 2500 cummins, it is the front diff u joint
Also how do I turn my idle up. I bought the truck a month or so ago and put it right in the shop to do some body work and wiring, just started driving it a few weeks ago and started haivng these problems. She has 215k miles runs like a top but was used as a farm truck and now I baby it and it needs to be my daily driver as well as my rodeo towing rig.
Please help
Old May 16, 2019 | 11:14 AM
MoparFanatic21
Please help
Start your own thread, don't thread hijack.
Old May 16, 2019 | 11:15 AM
lmbarrels's Avatar
lmbarrels
sorry did not know how this worked, pull your panties out and chill, first timer dude.
Old May 16, 2019 | 11:23 AM
MoparFanatic21
That was as calm as it could be. You should read the rules being a first time. It will provide a litter of helpful information. Welcome to the forums.
Old May 16, 2019 | 12:37 PM
Ram727's Avatar
Ram727
Alright I will look at the steering column. Anything in particular I should look for?
Old May 16, 2019 | 12:44 PM
MoparFanatic21
If you can get somebody to help have them turn the wheel and see if you see anything binding.
Old May 16, 2019 | 12:45 PM
Ram727's Avatar
Ram727
Alright Thanks
Old May 16, 2019 | 12:46 PM
MoparFanatic21
Alright Thanks
No problem!
