Blowing a fuse in 96 1500
Old May 21, 2019 | 11:14 PM
RyanHi's Avatar
RyanHi
Default Blowing a fuse in 96 1500
I had a radio installed in my 96 1500. The radio was spliced in. When I turn on the headlights the fuse blows . I still have headlights but no taillights or dash lights. I've replaced the headlight switch. Where should I start to look for the short or a wire hooked up wrong?
Old May 21, 2019 | 11:41 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Does the radio have an input for the park lights to dim the radio?
Old May 22, 2019 | 03:48 AM
DerTruck's Avatar
DerTruck
Start with the wiring they did when installing the radio, specifically the wire that carries the dimmed output from the dash illumination. Should be a 22g orange wire if I read the diagram correctly.
Old May 22, 2019 | 07:50 AM
If you just recently PAID someone to install the radio, take it back to them.
Old May 25, 2019 | 08:47 PM
RyanHi's Avatar
RyanHi
Orange wire is not hooked up to anything. Should that be hooked up to something?
Old May 25, 2019 | 08:49 PM
RyanHi's Avatar
RyanHi
The neighbor installed the radio. He's suppose to be a mechanic. Rather figure it out without him.
Old May 25, 2019 | 11:17 PM
RyanHi's Avatar
RyanHi
Figured it out. The radio ground was hooked up to a ground tied into a ground for the light switch. Hooked ground into a different ground and it works. Thanks for the help
