2002 ram 2500
Old May 26, 2019 | 05:54 PM
motorhead1960's Avatar
motorhead1960
New Member
Default 2002 ram 2500
So what idiot engineer thought that they needed to put cheap champion truck plugs in a performance engine? Iam have to cut the heat shields out of my way to get to the plugs, it's the 5.9 liter engine, any Idea's that would save the heat shields.
Old May 26, 2019 | 07:57 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Champion is the recommended plug for these engines...
Don't really need the heat shield just yank them out
Old May 26, 2019 | 08:10 PM
Moparite's Avatar
Moparite
I certainly wouldn't recommend them! AUTOLITES!
Old May 26, 2019 | 08:20 PM
Ramman18's Avatar
Ramman18
What genius decided to call the Magnum engines "performance engines?"
Nothing wrong with Champions. They last just as long as anything else and the engine runs great with them since they are the OE. Autolites sucked in my Magnum.
And all you need to remove the plugs is a socket. No need to worry about the heat shields. Hmmmm
Old May 26, 2019 | 09:33 PM
MoparFanatic21
Never had luck with autolites
Old May 27, 2019 | 06:18 AM
Moparite's Avatar
Moparite
When i first got my truck i ran Champions, Would get a miss in about a years time. Change them and same thing would happen again. Got tired of changing them then went with Autolites(plain copper nothing fancy). No issues at all with them.
Old May 27, 2019 | 09:46 AM
Spillage's Avatar
Spillage
I’ve always used NGK’s (V-Power copper core)... never an issue.
