Left signal and wipers 98 Ram 1500 Larime
Old Jun 21, 2019 | 04:24 PM
Ram4wd4u's Avatar
Ram4wd4u
Default Left signal and wipers 98 Ram 1500 Larime
When I activate my left turn signal the wipers go on . When the signal turns off the wipers cycle 4 times and turn off. I replaced the multi purpose switch but the problem remains. I checked the harnesses for a short but found none. Any suggestions would be appreciated. Thank you.
update: tonight I sounded my horn and it activated the wipers.
Old Jun 21, 2019 | 06:45 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I had that exact same problem, I can't remember what it was though
Old Aug 10, 2019 | 09:39 AM
Ram4wd4u's Avatar
Ram4wd4u
Does anyone have suggestions for this problem? Thank you
Old Aug 10, 2019 | 09:41 AM
Need to look at the wiring harnesses in the column. If you have tilt wheel, moving the column up/down tends to pull the wires out of their respective connectors, and can lead to all sorts of odd behavior. Gotta be a problem in the column somewhere.
Old Aug 10, 2019 | 11:51 AM
MoparFanatic21
Mine was a wire grounding out by the left turn signal socket
Old Aug 13, 2019 | 11:12 AM
Ram4wd4u's Avatar
Ram4wd4u
Thank you for the suggestions. Will check the harnesses.
