engine starts right up, then won't start
Old Jul 8, 2019 | 08:33 PM
monte355sb's Avatar
monte355sb
Default engine starts right up, then won't start
Hello All, My Ram 2001, 2500- 8.0l auto, 4x4, quad, long bed. Picked up an engine core. rebuilt completely. Whats new, T.P.S.- Oil pressure sending switch, Coil packs, wires plugs, What I have switched back to what is on old engine since issue. throttle body, crankshaft sending unit, I.A.C. Had injectors sent and pulse cleaned. when running engine sounds perfect, smooth and quiet. fuel pressure is at 42 P.S.I. book says 35 to 45 check. The only thing I noticed is the R.P.M idles at 700 solid. touch the pedal it shoots to 1400 you can't hold it at any R.P.M between? twice after trying to start it I get a back fire (EXHAUST) then runs perfectly even when I forget the #2 plug wire (checking spark) Any help? Thanks Dan
Old Jul 9, 2019 | 07:48 AM
Hhhmmm.... The 01 service manual says 49 PSI.... plus or minus 5, so, at 42, you are marginal.... Would be interesting to see what pressure is under load..
Do you have a scanner that can read data? If so, see what TPS is doing when you slowly press the pedal. (engine doesn't have to be running for that test) Backfire kinda indicates excessive fueling...... (yeah, counter-intuitive considering the low fuel pressure)
The V-10 runs smooth as glass, even with one cylinder dead..... What's even stranger is, my truck didn't even throw a misfire code, when I had a dead cylinder. The plug wire was burnt all the way through. No way that cylinder was firing, at all....
