No buss Ccd
99 dodge ram, 1500 5.9 V8 automatic trans 4x4
Truck starts, runs and drives perfectly fine. Issue occurs when the following: turn key to on position, will beep at me, abs, brake, gas light turns on/off, when truck is running at idle, the gauges will work fine then will die then start to work again, while driving issue mainly occurs when I'm off the accelerator or in 1st gear. while crusing and not in 1st gear, or highway speeds issue hardly occurs.
checked and replaced all fuses, relays are good, ran dash cluster test, codes are the following: 900 920 921 940 950 999.
The grounds In engine bay are char black, I think someone hooked up the battery backwards. Some grounds were disconnected or burnt off. I have connected the grounds, cleaned the grounds. I cannot find the ground going from the transmission to the engine or firewall. I have a junkyard PCM, I swapped the PCM, issue is still present.
I have a full engine wire harness, going to replace that today, any advice on where to go next will be appreciated.
found the primary issue. i fixed all the wires, truck is now not running properly, i replaced the crank sensor, going to put the old one back on and see where i stand, i dont want it to run until i get this fixed now. Idle is reslly rough.
Yarded all of this jank wiring and HOME AUDIO SYSTEM out of the truck. jesus people really amaze me.
issue has been resolved. PCM wire harness was rubbing on the cold air intake, I patched up the harness and wires and she drives great now, no more "No bus and CCd codes," Odo, Dash lights and gauges are working properly now.
Truck was running rough due to new autozone duralast engine crank sensor, dont buy from autozone problem solved.
