Wild Vents
Old Jul 30, 2019 | 12:04 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by Viperdave
Don’t forget to check the control head, yes they go bad, and they can get crap sucked into them from actuators that are going bad but don’t leak
pull the control head, find the port that gets vacum from the engine and blow .......slight......air pressure backwards into it, while doing that, turn the mode **** from one setting to another, you may get lucky and blow some stuff out of it. Now ya gotta find the bad hose or actuator
its worth a shot
I did that. I think it be the PCV valve
Old Jul 30, 2019 | 04:45 PM
MoparFanatic21
Here are the compression numbers
#1: 120
#2: 110
#3: 130
#4: 110
#5: 125
#6: 90 100 wet
#7: 125
#8 130
Plenum looks clean so I'm thinking valve stem seals are bad allowing oil to get into the combustion chamber. Probably going to do rings to but that is in the air. With two engine swaps coming up (408 and 6.4 Hemi) I'm not too worried.
Old Jul 30, 2019 | 06:16 PM
I would more suspect rings, than valve seals......
Old Jul 30, 2019 | 07:23 PM
MoparFanatic21
The only one that changed with the wet test was #6
Old Jul 30, 2019 | 08:02 PM
There can be only one....... No, wait. All it takes is one. Yeah, that's it. ALL of them are low though.......
But your pressure really didn't change much wet. I think a leak down test would be in order.
Old Jul 30, 2019 | 08:17 PM
MoparFanatic21
Im going to pull the heads anyway here in a few days when I do the Hydroboost. Bribe 2 plug wires abs a header bolt was just sitting on the header (ghost mechanic?). I have done note tests to run but #5&7 are a pain
Old Jul 30, 2019 | 08:24 PM
Do the hydraboost first. Then 5 and 7 are easy.
Old Jul 31, 2019 | 01:15 AM
MoparFanatic21
Oh believe me a lot of cursing was said on those two. Can't imagine you with the V10
Old Jul 31, 2019 | 07:42 AM
I cheated. I paid someone else to change the plugs/wires...... It was worth it.
Old Jul 31, 2019 | 12:20 PM
MoparFanatic21
Well mmt plan is this once I get everything together (still dealing with that damn vibration and now death wobble due to a bad track bar so I'm upgrading to the 3rd gen bar) I'm going to pull the heads replaced the valve stem seals, head gaskets, and change the rings if everything looks good. May get new heads if they are cracked but don't want to spend a liter of money as im building a 408 to put in this beast. Im going with a forged bottom end.
Can't cheat, you are missing the fun!
