interesting new stalling issue
Old Aug 3, 2019 | 05:23 PM
  #21
GreenRam5.2's Avatar
GreenRam5.2
So a fun new change today, i started the truck up after leaving it with the battery unplugged overnight and taking off the air cleaner to get a better look at all the connections and wiring and it idles high and fluctuates. this is new it has not done this before. i will pull the iac in the morning to check the connections and see if it needs another clean.
Old Aug 3, 2019 | 06:32 PM
  #22
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Disconnecting the battery will cause that until it learns where to idle. @HeyYou made a very good point (never thought of it). He says whenever you disconnect the battery turn the key on bur don't start it, and let it the for 15 seconds before starting. This allows the computer to learn the zero values of the sensors.
Old Aug 3, 2019 | 07:17 PM
  #23
GreenRam5.2
yeah i know, i have had the battery disconected several times during this and it has never done this so it is a new thing. i hope it leads to the issue.
Old Aug 3, 2019 | 07:22 PM
  #24
MoparFanatic21
Idle is controlled by both the IAC and TPS. I would suspect one of those
Old Aug 4, 2019 | 03:05 AM
  #25
mike48632's Avatar
mike48632
Have you checked the ground to the ECM
Old Aug 5, 2019 | 10:50 PM
  #26
GreenRam5.2
so another interesting thing popped up, i noticed that when i touch the plug for the tps it idles rough if i tap the tps it does the same and i could probably make it stall if i just keep tapping it. funny thing is i tested it and it tested ok. i am going to get a new one and perhaps a new plug too.
Old Aug 6, 2019 | 12:21 AM
  #27
MoparFanatic21
Get a Mopar unit
Old Aug 6, 2019 | 07:59 AM
  #28
Make sure the connections are good as well.
Old Aug 7, 2019 | 10:47 PM
  #29
GreenRam5.2
Get a Mopar unit
can't get a new one at the stealer they stopped making them in 2015 or so he says! non anywhere up here. ordered a jobber one and will try to find a good used original. i called all the wreckers around here they only have one 2nd gen left in the yards i will have to look farther out!
Old Aug 8, 2019 | 01:06 AM
  #30
MoparFanatic21
The are new ones on the internet just have to Google the part#
