over drive '95 2500 v-10
Old Aug 16, 2019 | 06:37 PM
Brad Farrow's Avatar
Brad Farrow
no light except when first starting and goes out rt away
Old Aug 16, 2019 | 06:39 PM
Brad Farrow
check valve
been removed, some wiring repaired on tranny 3 wires going into valve body vertical bt neutral safety switch
Old Aug 16, 2019 | 07:35 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by Brad Farrow
thanks for the info last dodge pickup I drove was my DNR '80 150 w/4spd(granny low) slant 6 w/2bbl. Thanks again I'm a listening if you got more good info.
I have an 86 W150 4spd with granny 318. Good trucks
Old Aug 27, 2019 | 01:00 PM
Brad Farrow
Default It’s getting better
Replaced temp sensor and they had spliced in the grounding part of solenoids for tranny operation. I will scab in to the PCM to see if it’s grounding path is good there. I’ll check the tranny loom connection. I think it had a poor grounding problem for the fools to cut in the circuits as such. The truck hauls *** when all plays together nicely. Thanks for the help on this.
