determine correct DRL module for 96 ?
Old Aug 18, 2019 | 11:17 PM
Brushy Bill's Avatar
Brushy Bill
Default determine correct DRL module for 96 ?
Bought a truck without working drl, switched out the module with a good used one with the same p/n and it worked...... for awhile
Wondering if the module is even the correct one, so before toasting another . How do I find proper p/n for this unit for my particular truck ?
Dealer only?
Old Aug 18, 2019 | 11:50 PM
dodgetruck2's Avatar
dodgetruck2
Dealer only?
Personally I've never owned a DRL equipped truck, but to answer your question yes, I'd say dealer, though I don't see what difference would effect the DRL module there's not much vehicle specific to it in my opinion, my best guess would be be there's a short or something in your wiring somewhere burning it out, or something causing excessive current draw
Far as part#s if all the numbers match you should be good the AA AB AE ECT just refers to the revision level AE being the latest revision in my example. If yours is an AA maybe try to find a later version. Regardless it wouldn't hurt anything to verify part number.
Moparpartswarehouse.com or moparpartsoverstock.com provide a dealer level parts lookup also
Old Aug 18, 2019 | 11:53 PM
dodgetruck2
Curiosity got the better of me I took the liberty, moparoverstock only went back to 97, that shows a Part# 56021561
