Check engine light, cylinder #6 misfire
Old Aug 19, 2019 | 09:59 PM
dmcochran's Avatar
dmcochran
Default Check engine light, cylinder #6 misfire
My check engine light came on and every time it does it says cylinder number 6 miss fire I have put new spark plugs spark plug wires Distributor cap and rotor. I put a new coil on and that seemed to a fix the problem it ran great Friday night and Saturday the check engine light came on again and with my super chip I diagnosed and it said number 6 cylinder misfire and to the touch all my spark plug wires are very hot I don't understand what is wrong. I have the 5.9 360 magnum motor
Old Aug 20, 2019 | 06:45 AM
Kyle Harrington's Avatar
Kyle Harrington
Be careful. Does it flash while your driving. Mine done this and is now down due to I have no clue what yet. Sounds like massive air leak did have misfire but fixed that now gaggles air so bad almost kills the truck. Also be sure to double check your wire routing. Hope you get it figured out. Good luck
Last edited by Kyle Harrington; Aug 20, 2019 at 06:48 AM. Reason: Forgot to add info
Old Aug 20, 2019 | 08:53 PM
dmcochran's Avatar
dmcochran
I was told to do a compression test cause it could be bad rings. Does that sound likely???
Old Aug 20, 2019 | 09:14 PM
99Ram1500sport's Avatar
99Ram1500sport
Check the air line running from the air box to the drivers side valve cover. If you have excessive vacuum, then you most likely have a blown plenum gasket.
Old Aug 21, 2019 | 04:55 AM
dmcochran's Avatar
dmcochran
I changed plentum plate with after market 1/4 inch thick aluminum plate and gasket 3 months ago. When I did intake manifold gaskets and valve cover gaskets and injectors, plugs,wires distributor cap and rotor
Old Aug 21, 2019 | 06:27 AM
Kyle Harrington
Ouch. As far as compression... strictly my opinion, yes , I think that it could be a possibility. Most definatly.
