I'm trying to picture in my head what's happening here. I don't think I've ever seen the button pop up on a proportioning valve. I know it will as I've tuned brakes and had to pop it up by hand (well, pliers) but I've never seen one do it by itself. Are the right rear brakes working okay? Has this truck been hauled on a trailer or pulled something out of a ditch with a chain around the axle tube? I ask just to make sure there's no damage to the steel line going to the right brake. Personally, if I change or rebuild one wheel cylinder, I do the other one also just to keep everything balanced. The brake shoes are clean aren't they? If the wheel cylinder leaked, brake fluid can cause it to grab. How is the brake cable for the parking brakes? Working normally? It may be the prop valve, although that's rare. Otherwise, I'm thinking there's something simple causing your issues.
Yea, to make sure we are on the same page..the "button" sits under a small rubber cap, on top of the valve..when my wife presses the brake pedal, the center of the valve, almost like a valve core for the tire pops up, just barely, but it does....There appears to be one on the bottom also, I can reach under, remove the rubber cap, but when she presses the pedal, it does nothing..No, never used it to pull anything, never been towed [to my knowledge]. Yes shoes are clean, brand new as well, everything seems normal...like I said earlier, for about 2 years, when I would first start and drive the truck, the first/second application of the brakes of the day, the drivers side would grab, but after 2/3 minutes...no problem...now, it can gat real grabby on drivers side...…..today I will go under and check all brake lines, to be 101% sure
