Rough idle and start
Old Aug 31, 2019 | 10:36 PM
Dodgeman459's Avatar
Dodgeman459
Default Rough idle and start
Just picked up a 97 1500 5.2 automatic 4x4 for farm use with 120,000 miles. It starts hard and idles rough when cold or warm. No loss of power and as soon as I give it gas it runs and drives perfect. It does seem a little rich in idle and misses. It has newer plugs wires. It runs even worse when I first put in in gear or stop. When I’m driving at low rms and just a little gas it kinda shakes but when I give more gas it runs just fine? Doesn’t stall
Old Aug 31, 2019 | 11:10 PM
Nicholas Seyfarth's Avatar
Nicholas Seyfarth
Throttle positioning sensor may be going out or you need to clean the throttle body
Old Aug 31, 2019 | 11:16 PM
Nicholas Seyfarth
Do this with the battery and throttle body disconnected.Then allow it to run with all electronics turned off radio, A/C, etc. This should allow it to learn the idle position. Let it run to operating temperature, meaning the coolant has reached its normal temperature as when driving.
