wierd idle on start up if it’s been sitting overnight
Old Sep 7, 2019 | 03:28 PM
Draven Matthews's Avatar
Draven Matthews
Default wierd idle on start up if it’s been sitting overnight
My truck has an issue when I start it it will start but then kinda bog down then back up and down for about a minute or two then you can hear it settle out and runs just fine. Only does it when engine is cold. I have replaced all sensors on throttle body new plugs and new exhaust system any suggestions please
Old Sep 7, 2019 | 07:59 PM
Have you cleaned the throttle body? IAC well tends to build up crap in it.
Old Sep 30, 2019 | 10:26 AM
jaze5736's Avatar
jaze5736
I am starting to have the same issue. When the engine is sitting cold for a while and i start it up it will idle up and down until it warms up and then it will run fine. Also when i put it in neutral and roll to a stop the rpms will slowly go up and down but seems to stay normal at a stop
