Busted vacuum line?
Old Sep 23, 2019 | 03:58 PM
99CubbyBlue1500's Avatar
99CubbyBlue1500
Default Busted vacuum line?
99 1500 5.2 4wd
These 2 pieces appear to be a broken vacuum line of some sort. The line comes out of the firewall beside the ac lines. Other end goes into the intake. Are these supposed to be connected? If so, will it be ok if I clean both ends well and splice them together securely? If not, how shall I repair/replace this piece?
Old Sep 23, 2019 | 05:52 PM
Torxhead's Avatar
Torxhead
I would suggest testing your hvac, it might be the main vacuum line that operates the vents. To repair it use heat shrink tube.
Old Sep 23, 2019 | 07:50 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
That's for your vent control, yes they go together!
