01 1500 steering upgrade
Old Sep 29, 2019 | 07:16 PM
rreichel99's Avatar
rreichel99
Default 01 1500 steering upgrade
Looking to upgrade to 3rd Gen T-style steering. All the other forum posts I see are referring to 2500/3500s. Looking to see what parts I'd need for my 1500.
Old Sep 30, 2019 | 10:59 AM
Ramman18's Avatar
Ramman18
That's because the parts are from the HD 2500 and 3500s. Don't get "3rd gen" parts, get "98-99HD" parts. 3rd gen parts will work with modification but refer to the factory "upgrade" from 2007 when Dodge realized all their stock parts were junk and snapping. Also the 3rd gen parts don't have grease zerks and you will have to modify your knuckles.
Just order all the tie rods and drag links with sleeves for the 99 2500 HD from rockauto. I would recommend the AC Delco line vs. the Moog because the Moog cheapened out by no longer supplying the required bushing at the passenger joint drag link. You would have to make your own like I did. Anyway, that's all there is to it. Everything fits and lines up especially if you have a 98-99 1500.
Old Sep 30, 2019 | 12:49 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
00- and up changed the tapers on the knuckles it won't be the right taper, whereas the 3rd gen T steering is the right taper
Old Sep 30, 2019 | 01:25 PM
rreichel99's Avatar
rreichel99
So if I went with the Moog DS800980A linkage assembly for 08 ram 2500, it should be the right setup for my 01 1500? It looks like it should come with everything I need.
Old Sep 30, 2019 | 01:36 PM
MoparFanatic21
I personally don't like MOOG but if it's for a 3rd gen Ram it will fit. Just Google "01 Ram 1500 T steering upgrade" you will find many threads on different forums regarding it.
Old Oct 1, 2019 | 09:59 AM
Ramman18's Avatar
Ramman18
He never stated a year. And with the 3rd gen swap you have to grind off some bolts to make it work. I think you mean the 4th gen steering 09-10 kits that all the diesel bombers install. But you hate diesel so never mind.
Old Oct 1, 2019 | 02:09 PM
MoparFanatic21
Don't know about the 4th gens steering upgrade. I know they have an issue with the TRE snapping as my truck has the recall. I was giving him the info as I would hate to see someone wreck. I don't hate diesel just strongly dislike them but they have a place in Semis
