97 ram 1500 plow setup
Old Dec 15, 2005 | 09:56 PM
CBR310's Avatar
CBR310
Default 97 ram 1500 plow setup
I have a 97 ram 1500.I just got a meyers plow setup. I need to get the peice that bolts to the frame. I priced it new @ 517$$ Anyone know where to get one used or cheaper?
Old Dec 15, 2005 | 10:54 PM
mattk's Avatar
mattk
Default RE: 97 ram 1500 plow setup
You can try plowsite.com and see if you can find one. I have a '97 Dodge Ram 2500 w/a meyers 8' plow on it. Where are you located and what exactly are you looking ? I have had mine for a couple of years but I just called yesterday for a new mount to bolt up to my truck and they quoted me $250.00 brand new. That was a local dealer here close to me. Let me know what you need and I will try and get you more info.
Matt
[IMG]local://upfiles/7229/C457F39AC07C4A6D8F29CF8DBA327259.jpg[/IMG]
Old Dec 15, 2005 | 11:59 PM
The Burning Rom's Avatar
The Burning Rom
What series plow do you have? In otherwords what hookup? Meyer has changed a few times over the years. There were some on ebay (for different setups) a few days back but they have since ended.
Old Dec 16, 2005 | 03:34 PM
CBR310's Avatar
CBR310
Its a ez connect? It has the two tubes in the front that the headlights slide into(which I cant get apart). It already has the rigging for a 2500 ram I think. its to wide for inbetween the frame rails of my truck, so i need the part that actualy hooks up to the frame of my truck. Thanks alot for the help.
Old Dec 16, 2005 | 09:39 PM
mattk's Avatar
mattk
Do you have pics of your setup? If you do send them to me and let me see what you got or post them to this. I have the EZ classic setup which I believe is the same as yours. I have the tube type slide in headlights w/the pump mounted to it. This comes off seperately from the plow. Is that the way yours is? I cant slide or take out my tube mount w/o using a sledge hammer. I have tried every lube I could and it still doesnt just slide in and out. Oh well, Let me know model # of your plow. Mine is an 8' commercial series and the model # is C-8. It should be on your plow somewhere. Let me know and I will try to help you find a cheaper mount for your truck.
Thanks,
Matt
