94 Ram-engine swap options
Old Oct 4, 2019 | 10:58 AM
Michael Oud's Avatar
Michael Oud
Default 94 Ram-engine swap options
I have a 94 Ram standard cab manual transmission and I was looking to swap the 318 for something with a bit more power. The only issue I face is I have a shaker and custom hood made to fit the intake. I would either like to pull some more power out of it or swap the engine but with the cost of the shaker and hood I’d hate/refuse to lose them. Any suggestions from you fine fellows?
Old Oct 4, 2019 | 11:16 AM
A built 360 would be perfect. And it would allow the use of the hood/shaker as well. Same basic dimensions, just more cubes. You could even punch it out to a 408, but, the kegger manifold would be a major power restriction on that...... M1, or Hughes Air Gap would be better, and you could likely use a spacer or something (if its even needed) to put the shaker in the right place.
