4th gen wheels
Old Oct 4, 2019 | 08:45 PM
jaze5736's Avatar
jaze5736
Default 4th gen wheels
For anyone interested in putting 4th gen wheels on a ram 1500 without a lift. I Recently put 4th gen wheels on my stock ride height ram 1500. They rubbed on the wheel liners but I removed them and there is enough space now. But it rubs on the inner plastic corner of the number which is simple to cut and then you will have no fitting issues. Although I do already have 2”spacers.
the bolt pattern on rams from 1994 to 2018 are the same and so is the hub size. Pictures comming soon.
Old Oct 12, 2019 | 02:38 PM
Dodge_OffRoad's Avatar
Dodge_OffRoad
I would really like to put 4x4 Rebel 17" rims on my 2001 ORE.
Old Oct 12, 2019 | 03:46 PM
Spillage's Avatar
Spillage
Originally Posted by jaze5736
...the bolt pattern on rams from 1994 to 2018 are the same and so is the hub size. Pictures comming soon.
That’s good to know...
Thanks for that snippet of information.
Old Oct 12, 2019 | 09:45 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Actually goes back to 82 4wd
Old Oct 22, 2019 | 06:19 PM
jaze5736's Avatar
jaze5736
I believe that the wheels i have 275 60r20 off of at 2017 ram and those tires are 33 inches. I have heard though that you can put 31 inch ties of without clearance issues except the calipers if you don't pay attention to offset. Has anyone made custom sort of wheel liners that only cover the inner sides on the wheel wells by the manifold so in the winter i wont get tons of junk by the engine?
