HVAC parts
Old Oct 7, 2019 | 08:30 PM
jaze5736's Avatar
jaze5736
Default HVAC parts
Hi, I was wondering what brand parts I should buy for heater core, blower motor, blend door, mode door and evaporator. Since i am taking the dash out I plan on doing them all and not having to deal with it again. So what brand should i go with for a long life?
Old Oct 8, 2019 | 10:17 AM
2bit's Avatar
2bit
Some of the cheap heater cores and condensers don't have the correct fin count. The don't transfer heat the way they are supposed to. I don't know how you would find out which aftermarket parts are built to actual factory specs. I would use Standard Motor Products for any switches or sensors. AC Delco would also be a good choice if you can find them somewhere. Don't forget to change the receiver drier and orifice tube. The drier should be replaced when the system is opened..
