No running tail lights, cluster and signals
Old Oct 6, 2019 | 06:24 PM
Tristin Ehrismann's Avatar
Tristin Ehrismann
Default No running tail lights, cluster and signals
So I have a 1996 ram 1500 5.2 and in the last week I’ve had a problem where my cluster was out and taillights were out but my break lights still worked and now two days later my cluster is still out my taillights and break lights are out and now my turn signals are out but my hazards still work? How does that work. I have fuses 18 and 20 are blown both are 15A and yes I’ve replaced the fuses and they blow as soon as I tap my breaks. I have done no recent electrical work but did shocks 2 weeks before this problem occurred
I don’t have the money to take my truck to a shop to have them diagnose it so your advice is better then mine
Old Oct 6, 2019 | 07:07 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
You have a working issue somewhere. Sounds like the power wire(s) are grounding out
Old Oct 6, 2019 | 07:25 PM
Tristin Ehrismann
Where should I go about starting to look for these wires
Old Oct 8, 2019 | 12:06 PM
MoparFanatic21
Start at the plugs themselves. I would use a test light and see where you are losing power. Use the FSM (you can get that in the FAQ section) and see where the connectors are
Old Oct 8, 2019 | 12:08 PM
MoparFanatic21
@HeyYou can you move this to the technical section, so he can get more help? My schedule is swamped
