Truck won't start after replacing water pump
Hello my name is Tom
1999 ram 1500
5.2 liter. 4+4
I just replaced the radiator and water pump .
I sprayed off motor when it was not running while I had pump off .
After I was done , everything was back together .
I tried starting it and didn't start.
Cranks over
Long story short . I replaced :
Camshaft position sensor
Distributor cap and rotor
Coil
Wires plugs
Can someone help me PLEASE
1999 ram 1500
5.2 liter. 4+4
Cranks over
Coil
Wires plugs
Trending Topics
When you replace the chain assembly, be sure to use the updated tensioner. Also, I always drop the pan when I do a chain and this would be a good time to go with a high volume (NOT high pressure) oil pump. I'll bet your engine has between 120,000 and 150,000 miles, if not more. The high volume pump will compensate for a bit of wear on the bearings making for a happy engine.
How in the world did the chain break?!!? It's a chain for crying out loud. That means something was probably interfered and your problems are just beginning. Valves in pistons, etc.
I replaced mine at 200k for preventative maintenance and it was barely loose. In fact, the new one had the same slack! And there's no tensioner on the magnums. That's an old LA thing or something. Just slap it on aligning the marks properly and off you go. But it's not a small job.
Chains can break. Not often, but they do. The Magnums do use a tensioner. I put a chain in a '94 3.9 and the dealer got me an updated tensioner. Smoothed that puppy right out. I suspect the OP had a chain jump a tooth. That can get it far enough out of time to not start. I don't think the first generation Magnums are interference engines. I know the second gen ones are.
