After replacing timing chain bad vibration
Old Oct 12, 2019 | 03:04 PM
Tommy Joe Bowman's Avatar
Tommy Joe Bowman
Unhappy After replacing timing chain bad vibration
Engine seems to be vibrating and sounds a little rough.
Old Oct 12, 2019 | 03:11 PM
Did you do anything else when you did the timing set? Did the distributor get turned at all? Cam or Crank while chain was off?
Old Oct 12, 2019 | 03:59 PM
Tommy Joe Bowman
The crankshaft was turned to line up the marks. And the distributor cap was off during the replacement
Old Oct 12, 2019 | 04:37 PM
Which marks? To set fuel sync, I don't think that is set at TDC.... Have a service manual for your truck yet? If not, get one here. Setting initial fuel sync process is in there. (look in the engine section, under distributor remove and replace)
Old Oct 12, 2019 | 05:02 PM
Tommy Joe Bowman
Default I have haynes
So other than marks lined up I need to do something to distributor?
Old Oct 12, 2019 | 05:06 PM
Hhhhmmmm....... Thinking on this a bit more.... if you had lined the dots up wrong, the engine wouldn't even start... (180 degree out on timing) If you didn't disturb the distributor, that should all be good.
Are you just getting a bit of a miss at idle? What kind of shape are the rest of the ignition parts in? (cap, rotor, wires, plugs) Is fuel pressure good?
Given that your chain actually broke....... You may want to do a compression test. As I think pistons can actually meet valves in these motors. Not 100% sure on that though.
Old Oct 12, 2019 | 05:09 PM
Tommy Joe Bowman
I replaced cap rotor plugs wire. And coil camshaft positioning sensor and fuel pump was replaced about 2 months ago.
Old Oct 12, 2019 | 07:59 PM
Is it missing immediately at startup? Or does it start missing only after running for a couple minutes?
Old Oct 12, 2019 | 08:31 PM
Tommy Joe Bowman
After a couple minutes
Old Oct 12, 2019 | 09:46 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Front O2 sensor could be bad
