Cannot remove pitman arm
Old Oct 14, 2019 | 02:00 PM
jaze5736's Avatar
jaze5736
Default Cannot remove pitman arm
So I have the pitman arm completely off except for where it goes around the splines to the steering box. I have rented the puller from auto zone. I hooked up the puller and couldn’t get it to go by hand or with an electric impact. The puller started the bend with the impact. Does anyone have an idea of how I can remove this?
Old Oct 14, 2019 | 02:18 PM
chromed95's Avatar
chromed95
Soak it in PB Blaster or a penetrate of your flavor for a few hours, a good day is best. Spray it above the arm on the splines so the penetrate can work it's way down the splines inside the arm Re soak every few hours. Bang on it with a hammer as you're trying to pull it off. If that doesn't work, bring on the heat torch. Heat up the arm around the splines, bang it with a hammer as you're using your gun and puller and that should pop free.
Old Oct 15, 2019 | 06:33 PM
Careful with the torch though, don't wanna trash the seal in the sector shaft....
Old Oct 16, 2019 | 06:29 AM
Moparite's Avatar
Moparite
What did it look like? Brand? You may have to get one that looks like this...
https://www.napaonline.com/en/p/OTC8150
Old Oct 16, 2019 | 09:37 AM
wca_tim's Avatar
wca_tim
get a better puller from someone - if you're bending the puller, it's not adequate... lots of times the cheaper pullers are made from crap metal. you need something made from strong forged or tempered steel...
I wouldn't use heat... I would try tapping on the sides near the splines, probably with an air hammer for a bit along with pb plaster or transmission fluid / acetone.
Old Oct 19, 2019 | 11:35 AM
Dirtymaxx66's Avatar
Dirtymaxx66
Hit it with a hammer as your pulling it off. And there's a chance the electric impact is not adequate. Those cheap autozone pullers bend when you use hand tools, I found that out pretty quickly.
I tend to tighten it up nice and tight and give it a good couple of good smacks on the bolt of the puller(bad to do if you own the tool, but autozone will take it back even damaged) then tighten it back up and repeat till it pops off, it's not fun to do and takes time
Old Oct 19, 2019 | 12:48 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
With the puller on and tightened as far as it will go then use 2 hammers, one for each side of the pitman arm, and hit simultaneously on the sides. This works some of the time.
