Can I swap parts to get a higher GVWR
Old Oct 16, 2019 | 08:19 AM
ol' grouch's Avatar
ol' grouch
Originally Posted by 00t444e
First of all I highly doubt any law enforcement will pull over a truck hauling a camper just to check the weight, recreational vehicles are exempt from DOT weigh in. However in the highly unlikely circumstance that you do get weighed by the DOT they go by your axle ratings not the GVWR so as long as you don't excede those rating you are still legal.
Actually, Motor Carrier Enforcement officers vary from state to state but they can inspect private vehicles. The main concern is the declared weight on your unit. Heavier rigs pay more in road taxes. If you have a declared weight of 10,000 pounds, and weigh 11,500, you'll get an over weight ticket. The fines for over gross can really add up. Indiana has raised the basic pickup weight from 7000 to 10,000 pounds. At one time, there was a 4000 pound plate but everybody ran them and would gross out at twice that.
The key here is to make sure the rig is stable. You can then raise your declared weight the next time you renew your plates.
Old Oct 16, 2019 | 08:22 AM
ol' grouch's Avatar
ol' grouch
All frames are identical no difference
The frame on my '01 Ram 2500 was substantially heavier than most pickup frames I've seen. More like a light cab and chassis used for box trucks. It's definitely heavier than a co-workers 2500 Cummins, however, his is a 2003 so the difference in years may make a difference.
Last edited by ol' grouch; Oct 16, 2019 at 08:23 AM. Reason: i kant spel wurth a durn.
Old Oct 16, 2019 | 09:28 AM
primem's Avatar
primem
its strictly enforced in BC Canada due to the mountainous terrain; rv's included. if over weight...you are stuck there until you get a truck that can tow the weight or you lighten the load so its in range.
to the op...dual rear wheels are a nice option when carrying a heavy slide in. a tire blow out on a single rear wheel truck is trouble.
Old Oct 16, 2019 | 09:33 AM
wca_tim's Avatar
wca_tim
lots of times brakes are a significant difference in towing capacity... vehicles rated with higher towing capacity have to be able to stop effectively with the additional weight...
pretty much nothing you can do will increase the legal towing capacity of your vehicle...
Old Oct 16, 2019 | 04:42 PM
Ramman18's Avatar
Ramman18
Yep, apples to oranges. Everything changed in 03 including frames, suspension, and axles. You answered yourself. But all 2nd gen 4x4 frames are the same, apparently.
Old Oct 16, 2019 | 10:27 PM
Ugly1's Avatar
Ugly1
Indeed. Compound that with my lift and tall sidewalls and it is a scary to think about about what happens at freeway speeds and there is a blowout. It's enough to convince a guy to spend more on tires than he might otherwise.
In this case my goals are being more offroad worthy and dual wheel axles kind of goes against that grain. I'm actually looking at downsizing the camper. I've been kicking around the idea of one of these offload friendly popups for a couple years , like maybe an Alaskan or something along those lines.
Old Oct 16, 2019 | 11:08 PM
Ugly1's Avatar
Ugly1
Hmmmm. Coincidentally I am just about done with my seemingly endless front axle swap to an AAM off an '01. Those have the dual piston calipers.....and it's really easy to upgrade to gen 3 brakes which have bigger everything.
I wonder if upgrading brakes would buy me anything. You know? Not with Johnny law but with the hypothetical insurance/court battle.
Old Oct 16, 2019 | 11:52 PM
Ramman18's Avatar
Ramman18
Once again, AAM axles didn't come on Rams until 2003. Axles in 2001 were still Dana.
Old Oct 17, 2019 | 12:33 AM
Ugly1's Avatar
Ugly1
Again? You said that earlier? Sorry.
The point is the bigger brakes....
Old Oct 17, 2019 | 08:34 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Getting a 99-01 Dana 60 will get you the bigger dual piston calipers. You can also upgrade to the 3rd or 4th gen brakes. Will be a direct bolt it except the from u joint on the driveshaft. I seen the biggest difference switching to hydroboost
