My 1997 1500 is leaking gas at the rubber hose between the filler neck and tank. What is it called, so I can order one? It only leaks when I fill the tank all the way.
Looking at the factory service manual, that would either be the rubber fuel filler hose or the rubber fuel vent hose, depending on which direction the fuel flows.
