NV3500 Swap Problems
Old Nov 5, 2019 | 10:53 PM
bgivner's Avatar
bgivner
Angry NV3500 Swap Problems
Hello,
I did the NV3500 swap into my 01 Ram with the 360 magnum. Most of the install was pretty smooth, long story short, the trans is coming out again for some work.
I currently have a check engine light (surprise, surprise), but not all of the codes are trans related. I have a code for a cam sensor intermittent and a crank sensor intermittent. P0340 and something else, i'll have to check. I replaced both sensors with no difference. Unplugging either one will cause a no-start. The thing idles like a m-fer and blows black smoke from running rich when you rev it. I tried resetting the codes, replacing sensors, driving it, using a different computer, and testing all the wiring with no avail. Turning the wheels at idle is enough to stall it. I'm lost, the trucks been sitting since April and I miss sitting higher on the road than my Jetta wagon.
I'm lost so here I am.
Thanks in advance.
Last edited by bgivner; Nov 5, 2019 at 10:54 PM. Reason: Edit: running RICH, not lean
Old Nov 6, 2019 | 12:23 AM
Ramman18's Avatar
Ramman18
Well, the trans has no sensors so no codes will be trans related.
The crank sensor can be damaged anytime the trans is R and R'ed so that's possible.
The big question is: did you tune the pcm or use a manual pcm for the swap? It cannot be run on the auto pcm.
Old Nov 6, 2019 | 12:47 AM
bgivner's Avatar
bgivner
Ramman,
I have 2 codes for the trans, maybe 3. Trans temp and shift solenoid. I did not have the PCM flashed, but I did try to use the computer from the donor truck and both computers gave me the same codes for the cam/crank sensors.
Old Nov 6, 2019 | 08:05 AM
Pull the crank sensor, and see what it looks like. Make sure the wiring for the cam/crank sensors didn't get pinched between the engine and trans. Also, there is a difference in crank sensors between manual, and auto transmissions.
Old Nov 6, 2019 | 10:19 AM
Ramman18's Avatar
Ramman18
Originally Posted by bgivner
Ramman,
Trans temp and shift codes are for the auto that the pcm cannot find any longer obviously. They need to be cleared somehow. You say both pcms gave crank sensor codes but did both give trans codes? Shouldn't be possible I would think.
Old Nov 13, 2019 | 10:47 PM
Xombi's Avatar
Xombi
where did you source the flywheel from? are there senders on the flywheel that could have been damaged? where did the driveshaft come from? If it is a nv 3500 I would think it came from a v6 and the pcm might be incompatible. I am rooting for ya because I have the same truck and am considering it.
Old Nov 13, 2019 | 10:55 PM
00t444e's Avatar
00t444e
Did you use a flywheel for a 5.9, or did you use one for a 5.2?
Old Nov 14, 2019 | 12:51 AM
Ramman18's Avatar
Ramman18
NV3500s were the transmission for all V8s as well. But yeah, the flywheel would need to be a 5.9 due to being externally balanced.
Old Nov 14, 2019 | 08:58 AM
Xombi's Avatar
Xombi
Default NV3500 swap
Were they used in the 2500 series as well?
Old Nov 14, 2019 | 09:09 AM
00t444e's Avatar
00t444e
2500s used the NV4500.
