Battery went bad new battery won’t start now
Old Nov 20, 2019 | 06:02 AM
Scottlogger's Avatar
Scottlogger
Default Battery went bad new battery won’t start now
Need help have a 98 ram 1500 5.2 ran great friday went to start it Tuesday battery was completely dead charged it won’t to try to start it no start turns over but no fuel no spark tries to start off starting fluid but only for a second and the amp gage doesn’t move same with fuel gauge .tested for fire at fuel pump none ,after try to crank it the odometer starts to blink but no codes help please checked the asd and all fuses is there away to reset the fuel pump like a Ford ? Or the factory security system ? Thank you for your help
Old Nov 20, 2019 | 12:29 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Does the odometer say "NO BUS?"
Old Nov 20, 2019 | 06:55 PM
Scottlogger
No just blinks hooked up my scanner but I can’t get it to link I think pcm might be bad
Old Nov 21, 2019 | 02:12 AM
MoparFanatic21
Usually it will say No BuS and that could be a wiring problem
