3.9 v6 to 5.9 v8 swap in a 2001dodge Ram 1500 single cab
Old Dec 11, 2019 | 01:43 AM
Jacee Young's Avatar
Jacee Young
Default 3.9 v6 to 5.9 v8 swap in a 2001dodge Ram 1500 single cab
Anyone know what exactly i need to swap a 5.9 v8 In to a 2001 3.9 v6 Dodge Ram 1500 single cab ? All I have so far is a 5.9 v8 out of a 1998 Dodge Ram
Old Dec 11, 2019 | 10:00 AM
Wiring harness, or, simply add the additional needed wires to your current harness. (two injectors) Reprogram the PCM to run the V-8. May need to extend some of the connectors if you use your existing harness for the sensors on the front of the motor. (temp, etc.) Aside from that, there are likely some other little things you will need, but, it's a pretty straightforward swap.
Old Dec 11, 2019 | 09:22 PM
00t444e's Avatar
00t444e
Auto or manual?
Old Dec 18, 2019 | 02:32 AM
Jacee Young
It’s an auto can I used a 5.2 harness or does it need to be a 5.9 harness
Old Dec 18, 2019 | 07:01 AM
00t444e's Avatar
00t444e
You will have to use the 5.9 flexplate and torque converter, along with the transmission. The 42RE that comes behind the v6 won't hold up well behind the 5.9, a 46RE is what the 5.9 uses.
Old Dec 18, 2019 | 09:37 AM
Either V-8 harness will work.
