2001 5.9 4x4 axle shaft
Old Dec 15, 2019 | 02:38 AM
Twangin4u's Avatar
Twangin4u
Default 2001 5.9 4x4 axle shaft
Does anybody know if an axle shaft with an abs tone ring on it will fit the same as an axle shaft that does not?
Old Dec 17, 2019 | 03:54 PM
KillerLemming's Avatar
KillerLemming
It most likely will not, plus your abs light will come on and you may not have abs as a result.
Old Dec 17, 2019 | 10:28 PM
Twangin4u's Avatar
Twangin4u
We will soon find out. My truck only has rear abs. I think the difference between the front having abs or not is the knuckle having a mold in it for an abs sensor to sit above the tone ring. I went a head and ordered the yoke end of the axle. 90$. The only one I could find had the tone ring on it. The whole shaft was $500.
Old Dec 18, 2019 | 02:16 PM
KillerLemming
That would make sense. How I understand it at first was you had front abs.
