98 Dodge Ram 1500 transmission help
Old Dec 16, 2019 | 01:44 PM
Sheldon Fuller's Avatar
Sheldon Fuller
Default 98 Dodge Ram 1500 transmission help
Hello, I’ve posted before, I have a 1998 Dodge Ram 5.9 4wd. I need to replace the transmission. Could someone give me a step by step on what to do to completely change the transmission. Also I am replacing because my transmission was submerged in water. So how would I get remaining water from oil cooler? Also could someone tell me how to do the check valve delete? All helps appreciated thank you.
Old Dec 16, 2019 | 06:06 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
They sell transmission line flusher at most automotive stores. It's in a can, like paint. Me, I use compressed air and trans oil. I used a drill and bit, going up in increments until the stainless disc popped out, it has a spring too under the disc. It's free if you have a drill and bits. Nothing that will hurt you when it pops out.
