Transmission pigtail part numbers needed
Old Dec 18, 2019 | 12:17 PM
Big Green 360's Avatar
Big Green 360
Default Transmission pigtail part numbers needed
I discovered that the connector pigtails going to the park/neutral position switch and the transmission solenoid are both damaged. The insulation is broken in several places and bare wire is exposed and visible in multiple locations.
Can anyone tell me where to get these vehicle side connectors and what the part numbers are?
Old Dec 18, 2019 | 07:34 PM
Moparite's Avatar
Moparite
Not sure if they have everything but have a look here...
https://www.standardbrand.com/en/pro...cal-connectors
Old Dec 18, 2019 | 07:50 PM
2bit's Avatar
2bit
DODGE > 1998 > RAM 1500 PICKUP > 5.9L V8 > Electrical-Connector > Neutral Safety Switch / Range Sensor Connector Price
STANDARD MOTOR PRODUCTS S1837 {#3U2Z14S411YLA, 5019923AA} Info
$26.79
DODGE > 1998 > RAM 1500 PICKUP > 5.9L V8 > Electrical-Connector > Automatic Transmission Connector Price
STANDARD MOTOR PRODUCTS S1838 {#5013933AA} Info
Control Solenoid; w/ Lock Up Converter
$22.79
I can't guarantee these are correct.
Old Dec 19, 2019 | 09:08 AM
Big Green 360
Thanks! I'll give these a try.
Old Mar 24, 2020 | 04:12 PM
Big Green 360
The S1837 was the correct part number for the neutral safety position switch, but S1838 is not the right part number for the transmission solenoid connector. S1838 is only a 3 pin connector, the part I need is an 8 pin. Can anyone help me find the right part number?
Old Mar 24, 2020 | 08:08 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
here you go
