Wierd problem - intermittent running lights
![Angry](https://dodgeforum.com/forum/images/icons/icon8.gif)
I'm experiencing an issue with the running lights not working consistently on my 1996 Dodge Ram 2500 standard cab 4x4 with 5.9 gas engine & 46RH transmission. Sometimes, they will turn on and work, but many times, I can turn them on and they won't work. The turn signals work and the brake lights & headlights work fine. I checked the fuses and they are all fine. I checked the wiring at the rear of the truck and it all looks fine. I pulled the headlight switch to see if it was overheating (wasn't) and as I was re-installing it, the running lights came on. Are there other places I should check to find my running light issue? Is there a relay involved that I should check?
I recently replaced the front fender and the truck bed before I had the truck painted. I did have a broken ground wire on the front fender. I fixed that broken ground wire at the front edge of the front left fender thinking it might fix the issue, but it didn't. I also had a missing ground wire on the truck bed (runs from the front right side of the bed to the frame). I replaced that ground strap too, but still didn't resolve the issue. I ordered a new headlight switch, however, I'm not sure if that will fix it. Any other places to look?
Look at the link, It's a recall on the 3500's but the 2500 and even the 1500's have had the same problem. Look at the terminal on the switch where it attaches to the rest of the switch. If it's loose or showing signs of heat replace it. Also look closely at the terminals on the connector for sighs of heat or melting. Dont buy the cheapest switch you can find, I went threw 3 of them(auto zone) before replacing both with a decent brand and problem hasn't returned.
http://dodgeram.info/tsb/recalls/819.htm
![Smile](https://dodgeforum.com/forum/images/smilies/smile.gif)
