tranny swap
Old Dec 20, 2019 | 09:58 AM
Diesel_cloud's Avatar
Diesel_cloud
Exclamation tranny swap
i have a 1995 dodge 2500 regular cab with the 360 motor and i believe its a nv4500 tranny. i have the truck i want to put the tranny into a 2000 dodge 1500 sport club cab. the parts truck has everything i should need to do the swap i just dont know how the wheel bases are if they're the same or if i need to get weird with driveshafts and i really dont want to. i already know that ill probably have to swap the pcms.
any input would be amazing and helpful. i just dont have the knowledge for this swap
Old Dec 20, 2019 | 10:28 AM
PCM's won't swap. Two entirely different systems, and they are not compatible. You can use the PCM already in the 2000, and just have it reflashed for a manual trans. I *think* all the mechanical bits to make it work will be fine though. Are the trucks 2 or 4 wheel drive?
Old Dec 20, 2019 | 11:16 AM
Diesel_cloud
Default reply
theyre both 4x4. i cant find anywhere from googling if the wheelbase is the same. dont wanna mess with the driveline if i dont have to
Old Dec 20, 2019 | 11:52 AM
I think you can use either transfer case, the 2500 should have the NV241, with is a bit heavier duty than the 231 in the 1500, I think the spline count on the output shafts are the same as well, so, your driveshaft *should* work. Either that, or should be able to get one from a junkyard without too much trouble. (the 241 t-case might be a bit longer than the 231, trans may not be the same length either) In any case, getting a shaft custom made really isn't that expensive. Friend paid less than 300 bucks to have his reworked. (need to be a bit shorter.)
Old Dec 20, 2019 | 02:11 PM
Diesel_cloud
i can re make the shaft myself. just dont want to.
i haven't been home in a year to be able to go check stuff so im attempting to find out as much as i can from the internet
