2001 1500 front driveshaft
Old Dec 30, 2019 | 02:22 PM
HeikIlm's Avatar
HeikIlm
Originally Posted by Joeyarsenault92
Does any one know any part numbers for all the parts to rebuild the shaft? Also where do you order the ball and what do you call it? I find it impossible to find online when it comes to ordering parts it's so confusing
Part numbers for the CV are on the post #3. But if you want greasable u-joint, 5-213X (grease fitting in body) or 5-1330-1X (fitting at the cap). And the bearing is found by the name unversal joint ball kit (617).
Front u-joint might be 1330-7290 combination joint (Spicer 5-7437X), but measure the cups before ordering. Two of them are 1.125" and other two 1.062" in diameter.
You can search parts from Rockauto, like 57437X for the Spicer 5-7347X joint.
Old Dec 30, 2019 | 03:19 PM
Joeyarsenault92's Avatar
Joeyarsenault92
thanks alot you guys are the best!
