2wd differential
Old Jan 11, 2020 | 01:21 PM
jaze5736's Avatar
jaze5736
Default 2wd differential
I have a 2001 ram 1500 2wd and the differential is making considerable noise. About a year ago all of the bearings inside the differential were replaced. At low speeds I can hear a sound from it that can only be described as a “wub wub wub” and a howling/whirring sound at high speeds. It’s loudest while accelerating but present at all times
Old Jan 11, 2020 | 02:01 PM
2bit's Avatar
2bit
That sounds like a brake issue. You could see if the pinion is loose and pull the cover to have a look inside, but I'd be looking at the brakes.
Old Jan 11, 2020 | 04:04 PM
Does the noise change if you step on the brakes??
How many miles since the rebuild? Any warranty on it?
