This is so strange. Could it be a discrepancy?
Old Jan 21, 2020 | 12:19 AM
Liddlez's Avatar
Liddlez
Default This is so strange. Could it be a discrepancy?
I was reading the manual of my ‘96 RAM 2500, and it called for 5 gallons (22qts) of coolant, but only 1 1/2 gallons fit. I flushed the entire system. Has this ever happened to anyone else?
Old Jan 21, 2020 | 12:40 AM
DerTruck's Avatar
DerTruck
Did you follow the procedures in the FSM ? 5 gallons would imply the truck is a 5.9 V8 which has block drain plugs.
Old Jan 21, 2020 | 01:33 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
As DerTruck said unless you drain the block you will get no where near that 5 gallons.
Old Jan 21, 2020 | 06:30 PM
ol' grouch's Avatar
ol' grouch
Was the heat control on hot? Between coolant in the block and heater core, you're holding a lot of liquid in the system.
Old Jan 21, 2020 | 10:05 PM
Liddlez's Avatar
Liddlez
it sure was! I followed procedure every step of the way. I drained the fluid via petcock on the radiator.
