97 Ram 1500 5.9 Issues Help Please!
Old Feb 1, 2020 | 07:20 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
Sounds like the CPS. And of course a Mopar one.
Old Feb 2, 2020 | 09:53 AM
Moparite's Avatar
Moparite
SMP has a good line, a value line, and also make BWD.
Stay away from BWD, Junk! Had to put in one of their crank sensors and it started to have issues within a few months. If you don't want to spend the money on oem go with Delphi sensors. They are a supplier to the auto makers. It's possible the oem ones are made by them.
Old Feb 2, 2020 | 11:38 AM
2bit's Avatar
2bit
BWD= Broken When Delivered, the parts stores will try to tell you BWD is the same as the good line from SMP. Liars!
Old Feb 2, 2020 | 11:39 AM
Schipper's Avatar
Schipper
CPS as in crank position sensor? God I hope not! It wasn't hard to change when I had the whole top of the engine off but it's gonna be a pain in the butt replacing it now 😭 I wish I would have known I was wasting my time with parts that were not Mopar 😭😭😭
Old Feb 2, 2020 | 04:56 PM
Schipper's Avatar
Schipper
Grab yourself a can of starting fluid. Pull the filter housing off the throttle body, and squirt some in there. If it fires, and runs for a few seconds, you have a fuel problem. If it doesn't fire at all, you have a spark problem. If you can draft a second person, you can also pull the coil wire off the coil, hold it a little bit above the coil, and have someone else crank the motor. The spark should jump that gap, if you are getting one at all.
Now I am pretty sure this truck is messing with me lol....my dad brought me home some starting fluid. I had started the truck before he went to the store and it died on its own and wouldn't start back up as usual. So now that I have the starting fluid I started the truck up to let it die so I could do the test. Except now the truck didn't want to die! The truck achieved normal operating temp and stayed running for over a half hour! Drove it in the driveway, turned the truck off and back on several times it started right up every time! My dad is telling me he thinks it's my fuel filter. Sounds like it could be that to me as well. So I guess on my 3 day weekend coming up I am dropping the gas tank and replacing the fuel filter. It and the pump are one unit aren't they?
Old Feb 2, 2020 | 05:30 PM
Schipper's Avatar
Schipper
Ok so I let the truck cool down a bit and then started it up and this it died soon after and wouldn't start back up again. I squirted the starting fluid down the throttle body still no start. I had my wife try starting while I held the ignition coil wire above the coil and I had spark!
Old Feb 2, 2020 | 05:35 PM
Spillage's Avatar
Spillage
Originally Posted by Schipper
... So I guess on my 3 day weekend coming up I am dropping the gas tank and replacing the fuel filter. It and the pump are one unit aren't they?
Yes, it’s all one drop in unit.
Get a Delphi pump... the cheapies are hit and miss quality... the last thing you need is to be dropping the tank again for the sake of a few $$
Old Feb 2, 2020 | 05:36 PM
2bit's Avatar
2bit
It's on top of the fuel tank. I don't see one available on Rock Auto, other than a complete pump assembly. I would try to get it to act up again and narrow down the problem. I haven't heard of many guys with a plugged filter. It's a stupid design.
Old Feb 2, 2020 | 05:38 PM
2bit's Avatar
2bit
It should've fired then though.
Old Feb 2, 2020 | 05:49 PM
2bit's Avatar
2bit
It almost sounds like an electrical issue. What brand parts did you use? Are the plugs plain copper or did you use platinum or iridium?
