96 dodge transmission
Old Feb 1, 2020 | 10:23 PM
TONY3374's Avatar
TONY3374
Default 96 dodge transmission
I have a 96 ram 1500 4x4 makes a clicking noise when under a light load almost sounds like parking pawl
Old Feb 1, 2020 | 11:03 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
You sure it isn't an axle u joint
Old Feb 2, 2020 | 12:10 AM
TONY3374's Avatar
TONY3374
Yes it's coming from transmission or transfer case
Old Feb 2, 2020 | 02:03 AM
MoparFanatic21
Check the snap ring on the output shaft of the transfer case common failure
Old Feb 2, 2020 | 11:37 PM
2bit's Avatar
2bit
+1 on the snap ring. Gilly's Transfer Case Saver is the best fix.
