ABS & Brake lights in dash are on
Parts store scanner won't show any codes as you can't read ABS codes on these trucks unless it's high end (a Snap-On couldn't even read the codes). Don't need ABS so it's not like it needs fixed right now. But what you can do is ground pin #13 in the OBDll connector (a wire will do) and count how many times the ABS light flashes.
Well, I finally got around to checking things out. I do have RWAL. When trying to ground pin #13, I find that there is no connection on pin #13. I called dealer and they want $100, up front, just to plug in and get codes. With VERY LIMITED FIXED INCOME, that is way off the page. I guess I'll try disconnecting the sensor on the diff and see what happens from there. If i have to, I can probably afford a new sensor, and go from there. Worst case, I'll leave it like it is and live with it.
Thanks to all that have given suggestions.
Dave
MopaarFanatic21,
Well, I finally got around to checking things out. I do have RWAL. When trying to ground pin #13, I find that there is no connection on pin #13. I called dealer and they want $100, up front, just to plug in and get codes. With VERY LIMITED FIXED INCOME, that is way off the page. I guess I'll try d isconnecting the sensor on the diff and see what happens from there. If i have to, I can probably afford a new sensor, and go from there. Worst case, I'll leave it like it is and live with it.
Dave
Dave
OK, slap me up side of the head and call me a dumb A**. i counted from the wrong side for pin #13. With the key on and the ABS light lit, there were no codes. The light did not flash. I used the key on, off, on, off, on to try to get codes that way. All I got to display was "P done". no codes that way either. I guess I'm just going to have to try to afford to take it to dealer for the $100 plug in and see what they say.
Thanks, again, for all the tips and advice.
Dae
MoparFanatic21,
Dae
Dae
Not trying to be a smart A**, but yes, it was a good ground to the battery negative post. The ABS light did not flash a code. I called the local "Stealer" yesterday and they want $100 up front to plug in and check it out. Also, they said that the first opening would be next week Friday afternoon. I finally got to talk to their brake guy (supposedly) and he said it sounded like there was air in the system and it would need to be bled. Asked service desk and they said Brake bleed would be about $300, as it would take about hours. My wallet is already screaming and I haven't even touched it yet. I guess it will have to sit until I can afford to put into shop.
Thanks to all for the advice and tips.
Dave
According to what it says in the service manual(1996), you have to have key in ON position, then momentarily ground pin 13. When the ground is removed the abs/brake warning light will begin to flash. Not sure if anything changed since then but could be 1 threw 15 different codes.
Moparfanatic21,
Dave
Dave
That is EXACTLY what i did. No codes came up.
Dave
I know when I do it I attach the wire to ground an then jam in it pin #13 sometimes it takes a few tries. When it does ground the light will dim for a second. I remove it and it flashes.
