1999 2500 wheel/tire combo
I have a line on some Pro Comp 16x10's with 4.5 BS that I need to commit to one way or another quickly. Currently running 315/75/16's on stock 6.5 in wide wheel and while it works, its too narrow. I'm leveled in front with arms extended about an inch to push the wheel forward. Anybody running these wheels (size)? Curious as to what I can expect.
They are going to stick out several inches further than stock, but, I do believe backspacing is the same, so, probably make your tires effectively a bit wider, so, they will probably rub with only a leveling kit.... But, you might get lucky.
10's are a bit wide..... but, if the price is right, give 'em a shot. If they are too wide, you can always re-sell them later.
