wont get passed 140
Old Mar 4, 2020 | 02:38 PM
proVIP3R's Avatar
proVIP3R
Default wont get passed 140
alright im stumped my coolant temp on the gauge will not get passed 140 and every now and then the computer will throw a overcooling code. i have replaced the temp. sensor, new coolant,2 new thermostats and it did it before the other thermostat change. does the computer read off of the gauge temp or the temp sensor. because idk whats wrong
Old Mar 4, 2020 | 03:00 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
what year truck?
Old Mar 4, 2020 | 08:16 PM
ol' grouch's Avatar
ol' grouch
What engine and how many miles on it? I'm thinking you have 140,000 miles or more and your timing chain is stretched. It'll still run but won't ever really warm up. If you know what to listen for, you can hear timing chain slap under the water pump.
Old Mar 12, 2020 | 02:30 PM
proVIP3R's Avatar
proVIP3R
2001 360 v8
Old Mar 12, 2020 | 03:33 PM
Only one sensor, and the PCM tells the cluster what to display.
What brand/type of thermostat are you installing? If you are using 'safety stats', don't. They suck. Get a good Stant thermostat, (NOT the 'safety' variety) and try again. Might not hurt to pick up an infra-red temp gun, and see what temp the thermostat housing is actually getting to. It's possible the sensor simply isn't grounding to the manifold good enough to work properly.
Old Mar 12, 2020 | 04:18 PM
volaredon's Avatar
volaredon
Clutch fan seized?
Old Mar 17, 2020 | 03:49 AM
proVIP3R's Avatar
proVIP3R
i purchased a WVE sensor
Old Mar 17, 2020 | 09:13 AM
ol' grouch's Avatar
ol' grouch
Ever check your timing chain?
Old Mar 25, 2020 | 03:15 PM
proVIP3R's Avatar
proVIP3R
so i figured it out i covered the radiator with more than half with cardboard and the truck finally got up to operating temp so i am assuming the fan clutch is stuck full engaged
Old Mar 25, 2020 | 05:46 PM
Torxhead's Avatar
Torxhead
Yes, it can and does happen. Rotate it by hand to check its operation.
