P0108 - the code that keeps on giving
Old Mar 9, 2020 | 06:00 PM
MAP needs to reflect some version of reality. See what the numbers look like at idle, and with the engine off. You should see close to 20" of vacuum at idle.... if you don't, need to find out why.
Old Mar 9, 2020 | 06:03 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by Dr97!
Mopar, what MAP should I go with? AutoZone was around 90
I try to get Mopar when I can. If not Standard Motor Products usually works. When you get the scanner check the MAP, then I can compare it to mine (a known good one) and we all with take it from there
Old Mar 19, 2020 | 03:49 PM
Dr97!'s Avatar
Dr97!
Default Update
New Plenum from Hughes, still throws code, map reads 5V no matter what, next step is replacing PCM. Wish me luck / give me recommendations ?
Old Mar 19, 2020 | 05:56 PM
Unplug the map, and see if you still get 5 volts on the signal return wire. Wonder if you have a short somewhere.
