Weak starter?
Old Mar 10, 2020 | 01:46 PM
spencer01's Avatar
spencer01
Default Weak starter?
My 2000 ram 1500 (5.9 magnum) has an issue starting, I have to rev it to get it to fire most times and if I turn it off and try and start it, it wont start unless I wait about 20 - 30 minutes, then it will start up if i rev it. Ive replaced the battery, alternator, and starter relay, spark plugs were checked, should I just replace the starter or is it something else?
Old Mar 10, 2020 | 02:35 PM
2bit's Avatar
2bit
How fast is it cranking? If it's cranking at a decent speed and just not starting, it's fuel or spark. Could be a crank sensor. Get a Mopar or Standard Motor Products sensor. Don't waste your money on BWD, Duralast, or the other parts stores junk.
Old Mar 10, 2020 | 03:12 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Need to see what toy don't have when it won't start. My guess is the crank sensor. Only buy Mopar sensors.
